MsiError 1627: 1: 2727 2: <Not A Path>
Hi LabVIEW community!
I have created a lavbiew project ("".lvproj), and build an installer. and it goes well. i have the setup.exe ready for installing, but when i tried to install it theres an error occur at the early stage of installation.
by the way im using LabView 2015
(2,457 Views)
Can you provide us with more information? maybe you can post the VI and the installer you make and maybe the hardware you use
Kudos and Marked as Solution == Thanks
(2,436 Views)
