Multi Channel DAQ Issue | NI USB 6212
Dear Community Members,
Hope you are doing well. I am trying to take data from two sensors and acquire data simultaneously. Through my code, both of the sensors are giving data separately. But whenever I am trying to get data simultaneously, then I am getting some errors. For example, the sensor data seems entangled. If I press on one sensors, in the code I find that there is changes in voltage on both of the sensors. But it should not happen. Could anyone please help me on this problem?
I have attached the circuit diagram and code in the attached files. Additionally I want to mention that I am using 24V external power supply.
Thank you
(1,353 Views)
Accepted by topic author Jarir
The behaviour you're observing is called Ghosting and is quite common in DAQ with multiplexed ADC.
Please read more here - https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P84RSAS&l=en-US
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YHy6CAG&l=en-US
https://www.ni.com/en-us/support/documentation/supplemental/06/is-your-data-inaccurate-because-of-in...
Santhosh
Soliton Technologies
(1,349 Views)
