Multi Numeric Limit Test define Array Size of Limits from LabView
i have a new problem. I want to change the array size of numericarray and Step.Result.Measurement from LabView.
I want to do the same thing i can do when i use Edit Limits and press the button Add or Remove.
When i only give them a define array from Labview it doesn't work.
Thank you
best reguards
(2,638 Views)
Dear Tumbler
I think the following thread should answer your question:
http://forums.ni.com/ni/board/message?board.id=330&message.id=2826&requireLogin=False.
Best regards
Philipp Roessler
(2,611 Views)
