Multi Plot Chart with TIME in the X-axis
I thought I had it figured out as I had my chart buffer set to 360 instead of 3600 but that was not it at all.
How do I get the X axis to line up with the data? The start time is correct (9:59) but as you can see it was 10:13 when I took this screen shot.
=== Engineer Ambiguously ===
Message 11 of 20
(3,414 Views)
Hi RTSLVU (is that Real Time System LabVIEW User?),
Here is an example where I set the offset to the current time. I am gathering data every 100ms, so I set the multiplier to 100ms (in seconds). I want to show 10 seconds worth of data, so I make the chart history be 1000 points.
Message 12 of 20
(3,409 Views)
You want 3600 datapoints in 1 hour, so just leave your multiplier at 1 (second). Only modify the XScale.Offset (nothing else).
Message 13 of 20
(3,401 Views)
So you are saying I need to update the Xscale offest with the current time everytime I updae the graph, not just once at the start of my program?
Message 14 of 20
(3,389 Views)
No, just once at the start of data acquisition should be good. I have not set autoscaling on, nor have I touched the X Scale min or max. I just set the offset and multiplier once, choose an appropriate history length, and let the chart do the rest.
Message 15 of 20
(3,383 Views)
Okay I am taking meaurments every 10 seconds and want to disply the last hour on the graph so that would be a history length of 360 and a multiplier of 10?
Message 16 of 20
(3,371 Views)
Yes, that sounds right!
Message 17 of 20
(3,363 Views)
Nope, that's not really what I want either.
I need a chart that will start out with the current time on the left end of the X-axis and current time plus one hour on the right.
Then once the data reaches the right end the chart should scroll to the left  always showing the last hour of data on the chart.
Message 18 of 20
(3,356 Views)
Accepted by topic author RTSLVU
Sorry about that, I guess I just got lucky that the max was already set very close to what I wanted. In your case, I think you should set the max to the current time plus 3600 seconds so that it is 1 hour out. I just ran an accelerated hour (changed the wait to 100ms instead of 10000ms) and it seemed to scroll just like you wanted.
Message 19 of 20
(3,348 Views)
So far so good! We will see in about an hour if it scrolls like I want.
Message 20 of 20
(3,332 Views)
