Multi Waveform Graph
Hi Philip,
If I do it using your logic the chart does not display 800 points of data from daq.Please look at the screen shot.Can you plzz look at it?
Ram
Message 21 of 24
(1,894 Views)
Message 22 of 24
(1,810 Views)
You didn't implement the most important part of my code (see attached "AppendDataArray.JPG"). This part of the code appends the acquired data to an array until it reaches the size of 800 points. After that, the data is still appended, but the old part of the array gets removed to keep the size of the array at 800 points.
Good luck!
- Philip Courtois, Thinkbot Solutions
Thinkbot Solutions
Message 23 of 24
(1,803 Views)
Awesome..... thanks a lot philip it works perfectly!!!now I can complete my thesis on time...Thanks a lot once again With out your help it would have taken me forever.....
Message 24 of 24
(1,775 Views)
