Multi-languages labview application
Is it possible with labview to do a multi-languages application?
I want the user to be able to select language in the execution menu, then,
it will translate all label with languages information from a configuration
file.
I know haw to use configuration file, but i don't know how to change all
label easily.
Can anyone help me?
Jean-Michel.
(3,124 Views)
"jm" wrote in message
news:3e2e75cc$0$226$626a54ce@news.free.fr...
> Hi,
configuration
> file.
> label easily.
The easiest way is to make a recursive vi. This vi would read a
configuration key, e.g. viname.tabname.clustername.controlname= "some text".
The recursive vi must look for the viname. Then it should get all objects,
and find a refernce to the tabname. Then it should find all names (on the
tab) again, and find the clustername. Then it should find all name
s (in the
cluster) and find the control name.
In pseudo code:
for all keys in the section of the selected language:
ref= vi ref of the first name
while there are names in the key
get all controls that are in ref
find the ref with the proper name
endwhile
set the name of the reference to the name in the key
endfor
Wiebe.
> Can anyone help me?
> Regards,
> Jean-Michel.
(3,124 Views)
>file.
Don't show the "Label Name" but use "Caption" instead. Then
programatically change the property "Caption Text" corresponding to your
translation configfile.
Good luck, Peter
(3,124 Views)
