Multi monitor + DAQ Problem (Freezing)
Hello All,
I searched the forum but couldn´t find a similar thread
I´m having a problem with multiple monitors in LabVIEW when usind DAQ.
I have a main VI which can call several subVI´s front panels, that can be located on any of the 3 monitors setup.
The problem: when i drag the window to another monitor, the subVI freezes until i change the value of a Digital In on the phisical panel.
When i used the VI whitout DAQ, this didn´t happen.
I´m using LabVIEW Full 2009 + Windows 7.
The Hardware: NI 9425, NI 9476, NI 9264, NI 9205
Thanks in advance,
Philipe
(2,722 Views)
Any suggestions?
(2,679 Views)
Good afternoon,
Please provide the version of DAQmx and happens every time or now. Thank you.
Sincerely,
Mauro Vera
(2,672 Views)
Hello Mauro,
The problem occurs almost every time i drag the front panel window to another monitor.
I´m using DAQmx version 9.4
I believe it´s the latest.
Thanks for the reply,
Philipe Massad
(2,668 Views)
