MultiPoint Read Questions using a 4071 and 1065 PXI Chassis
I'm using LabVIEW 2018, NI-DMM 20.00.  I'm trying to take readings using a PXI-4071 DMM and trigger it off the clock from the PXI-1065.  Is that possible?  I'm trying to take DMM readings as quickly as possible off the PXI-1065 clock.   Right now, I'm having issues.  I keep timing out.
Message 1 of 1
(902 Views)
