Multiband Filter synthesis in LabVIEW
Is there some facility in LabVIEW that allows to synthesize multiband filter, or one should use some other tool like Matlab.
Thanks in advance
Paavel.
(4,453 Views)
Hey Pavel_47,
what about the Signal Processing function palett?
Maybe this:
Musical Signal Processing with LabVIEW - OpenStax CNX
http://cnx.org/contents/GABeorRX@3/Musical-Signal-Processing-with
(4,423 Views)
Hi Brandizzl,
Your link needs some time to explore. Concerning Signal Processing function palett, did you see multiband filters there ?
I've only seen low-pass, high-pass, rejection and bandpass - always 1 band.
Pavel
(4,411 Views)
Accepted by topic author Pavel_47
What about this one:
Parks-McClellan VI - LabVIEW 2012 Help - National Instruments
http://zone.ni.com/reference/en-XX/help/371361J-01/lvanls/parks_mcclellan/
In addition, if you have enough resource and it if your program isn't time critical, you could simply put some filters in series.
Are you programming FPGA? What do you want to do at all?
Greetings
Brandizzl
(4,392 Views)
Greetings
Brandizzl
It's exactly what I serched for. No, I don't work with FPGA.
(4,374 Views)
