Multicolors in string?
I can make sections of text in a string indicator different colors
manually but I can't figure out a way to do it programmatically. The
goal here is to highlight two sections of a long text string by making
them different colors while leaving the rest black. Any ideas??
Tom
(3,161 Views)
Use a property node and select the text you want to change the color of by setting the Text.SelStart and Text.SelEnd properties, then have a third input to the same property node with the Text.FontColor property. Write the color you want to that.
(3,161 Views)
You must select the text first.
Property node -> text -> Select -> Start
Property node -> text -> Select -> End
Then...
Property node -> text -> Font -> color
It doesn't look like you can change the background for individual characters though.
Hope that helps.
Cheers
"Tom Whitaker" wrote in message news:pqma205tpob3nvqdsbje59vtk0520q79po@4ax.com...
> Tom
(3,161 Views)
Martin,
Thanks, that did it. I was using
Property node -> text -> text colors -> text color
and the whole string was turning color (even after selection).
Thanks again.
Tom
On Sun, 08 Feb 2004 00:53:42 GMT, "Martin Riddle"
>Then...
>Hope that helps.
>Cheers
>> Tom
(3,161 Views)
