Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Multicolumn LISTBOX - Hide (make not visible) a specific column
tonitpp
Active Participant
02-17-2005
07:54 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I have a little problem:
How can I hide (make not visible) a column of a multicolumn listbox in LabVIEW?
Is it possible?
ToNi.
0
Kudos
Message
1
of 2
(3,286 Views)
Reply
Re: Multicolumn LISTBOX - Hide (make not visible) a specific column
bushman
Member
02-17-2005
01:38 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Use the property node.
Set the active cell to the column you want to hide
Then set the column width to zero.
The data is still there, just not seen
Greg Bush CLAD
3
Kudos
Message
2
of 2
(3,273 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
