Multicolumn Listbox - Unwanted white selection box
Hello everyone,
I am seeing undesired behaviour with my multicolumn listbox (as seen in the attached picture) when selecting an item. I have searched for smiliar issues but I did not find a solution - nor did I find any properties that could disable what I am seeing.
Any help would be appreciated. Thanks,
Marcin
(4,784 Views)
A couple things you could try:
1. Ensure "Editable Cells" is turned off.
2. If #1 doesn't help, try setting the KeyFocus property to False.
I have yet to reproduce the behavior you saw so I'm not sure if those will help.
Quentin "Q" Alldredge
Chief LabVIEW Architect, Testeract | Owner, Q Software Innovations, LLC (QSI)
Director, GCentral | Admin, LabVIEW Wiki | Creator, The QControl Toolkit
Certified LabVIEW Architect | LabVIEW Champion | NI Alliance Partner
(4,769 Views)
Unfortunately those didn't help. Prior to launching the software I execute some init code as below,
Setting CellBG to transparent doesn't eliminate the issue.
(4,764 Views)
// duplicate
(4,761 Views)
In the Selection Mode menu, is "Highlight Entire Row" checked? Are you changing the row color somewhere else in your code?  The only way I can simulate anything like this is when Highlight Entire Row is unchecked.
aputman
(4,722 Views)
Accepted by topic author MPolaszyk
I managed to fix the issue simply by disabling and enabling the field - still not sure what caused it though.
Cheers for the input
(4,697 Views)
can you share the code with issue? Will try to replicate the issue and try to find the actual problem.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(4,693 Views)
