Multicolumn Listbox go next line with enter at run-time
I have a multicolumn Listbox which I fill with values from an XML file. I want to able to edit "some" cells and save it again to XML.
Each row has a special column, in which it is indicated that whether the 3.column in that row editable or not. This column contains RO or RW, If it is RO I discard the editing, if it is RW I accept the editing. so far sogut. But If I enter text in the cell and press enter, it does not go to next line. How can I go to next line for editing next line after pressing enter at run-time?
Thanks.
(2,796 Views)
Use an event structure to capture key events on the control.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,769 Views)
Oh, and it would probably be easier to use a table control over a list box.
Mike...
LabVIEW Champion
(2,768 Views)
