Multicolumn listbox changing or updating value in run time
Hi is there any possible to give value to multicolumn listbox in run time.I have attached an vi in that multicolumn list box contain three test i need to get input from user how many times induvidually each test should occur for example test1 3 times ,test 2  1time,test3  4 times.i need this details to be updated by the user in the multi column list box in the run time .but i cant do that in run time help me out
Message 1 of 17
(12,269 Views)
Hello... 🙂 I think you forgot to attach the VI... 😉
Have you tried with property "ItemNames" & try to use array function, Prompt user function... 🙂
Just a thought... 🙂
Message 2 of 17
(12,268 Views)
Ho sorry .i need to update from front panel ya here is the vi
Message 3 of 17
(12,266 Views)
Right click on the table and select 'Editable Cells'.
Message 4 of 17
(12,242 Views)
Hello.. 🙂
I'm unable to open the VI as I'm using LabVIEW 7.1... 😞      But I think you should try with the properties only... 🙂
Best luck.. 🙂
Message 5 of 17
(12,217 Views)
Hi i tried that it is not working ya.i need to give input in front panel
Message 6 of 17
(12,212 Views)
Can you please describe what you did....?
Message 7 of 17
(12,207 Views)
Nothing in that demo hust i kept the multicolumn list box inside the while loop.i need to update the multicolumn list box in front panel in run time
Message 8 of 17
(12,208 Views)
Hey.. I have done a small VI to update the  multicolumn listbox.. See if it hepls... 🙂
 The VI is in LabVIEW 7.1
Message Edited by Rupali on 09-30-2008 12:21 AM
Message 9 of 17
(12,205 Views)
Hi we cannot do that with out poping up the sub front panel with out updating in the main front panel
Message 10 of 17
(12,200 Views)
