Multifetch: How can I save recorded waveforms after timeout?
Hi, I have a data aquisition witch the "NIScope Multifetch.vi". I fetch n records of 2 channels of the Digitizer pxi-5114 at one measurement. The datarate is different, so sometimes the timeout occurres. In this case all sampled datas from this measurement are deleted. My question: How can I get the Multifetch-vi to give me the partial datas? Thanks!
(2,833 Views)
Dont you feel it is better to save the data anyway. You can retreive the data later ?
(2,824 Views)
Instead of using a fetch with a timeout, try polling for the driver status.  Fetch only when everything is available.  I believe you can use NI-SCOPE properties to set a subset of data for fetching, so you can also fetch pieces while other pieces are being acquired.  However, I am away from my development machine at the moment, so cannot give you specifics.  Look for "fetch forever" examples in the NI-SCOPE examples.
Good luck.  Let us know if you need more info.
(2,821 Views)
