Multilanguage user interface
Recently i am working on Multilangauge Labview code. For that i am Using Unicode Vis.
I found the problem when i am using the Unicode Text for Ring text Control.
The name in the Ring text Drop down shows the only first characters. Actually i want full name as per saved in database in Ring text Drop down box.
Here i have attached one image of ring text drop down menu.Attached image text was written in Russian Langauge. I am working on Russian and English languages.
In image you can see that Russian language characters shown as per saved in database but English characters not shown properly as per datab
Please help me to solve this...
(3,781 Views)
Please share sample code.
(3,756 Views)
(3,738 Views)
I'm pretty sure this is a known bug, Text Ring vs Unicode.  It's been so long since I worked with Unicode in LV that I have forgotten what the workaround, if any is.
Bill
CLD
(Mid-Level minion.)
(3,728 Views)
Please Suggest me any alternate for text ring for Unicode list selection. I tried combo box but not working.
(3,707 Views)
I had attempted to do multilanguage user interface in LV with undocumented unicode properties and failed miserably. At the end there is always property or control that can not be translated and it will be dead end sooner or later.
I belive all we can do is to relay and work based on OS codepages and regional settings.
This approach is used in this module: https://www.ni.com/en-us/shop/product/localization-toolkit-for-labview.html
This wil not allow You to switch on the fly between languages with diffrent charsets.
From what I see NXG will support unicode and all problems above will be solved 🙂
(3,701 Views)
