Create four Memory tags, one for each channel. Wire these channels' values to the respective Memory Tags using the Write Tag VI. Also, enable logging on these Tags so you have the data in the database.
Then cycle through these Memory Tags and write them out to your Modbus 30016 Tag.
Hope this helps.
Khalid 🙂
