Multiple 3 D lines in one plot
Hi!
I want to rotate 3D lines in one picture.
For this i want to draw about 1000 lines which i can rotate speratly.
How can i draw sperate lines in one picture?
For rotation I change the start end the end values from the lines.
but how can i change the line from solid tho piont and backwards?
or is there an other way`?
thany you
hannes
(2,536 Views)
I am wondering why you don´t use the 3D-Graph? The 3D Graph has a rotation-functionality built in, and you can plot multiple 3D-lines in it.
Here you can find some examples:
http://zone.ni.com/devzone/cda/epd/p/id/1028
Hope this helps!
(2,512 Views)
