Multiple CRIO's and shared variables - external PLC
We have multiple cRIO's that communicate via shared variables (hundreds of them).
Now we have an external PLC that needs to access (read/write) some of those cRIO shared variables.
What would be the best way to go about this?
I've read this page, that tells me you can add an OPC Server add-on to the shared variable engine. This will install an OPC server that creates OPC tages that are linked to the shared variables.
IS this also feasible for cRIO? Would I need the DSC toolkit for all cRIO's that the PLC needs to communicate with?
Would there be a better way?
(1,243 Views)
HI thomas,
I will share with you 2 articles that might help
Support Files to Include when Building a LabVIEW DSC Module Application
https://www.ni.com/en/support/documentation/supplemental/21/support-files-to-include-when-building-a...
Using and Deploying NI OPC Servers, DSC, and LabVIEW OPC UA Toolkit
https://www.ni.com/en/support/documentation/supplemental/18/using-and-deploying-ni-opc-servers--dsc-...
(1,206 Views)
