Multiple Dynamic Select
Any suggestions on how to select (Boolean) a list of items that are dynamic?  I need a control that can scale to any size (< 50 element) so the customer can select what gets written to disk.  My first thought was a Boolean array but can’t create unique labels. List box doesn't scale dynamically either.
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(4,135 Views)
I don't agree (or else i'm not understanding you) with you, when you say that listbox it's not dynamic. You can dynamic change it's content trought the property "itemNames".
Software developer
www.mcm-electronics.com
PORTUGAL
(4,133 Views)
Sorry, I was trying to say radio buttons.  I guess a list box will work for the task.  I was think more along the lines of a boolean control.
Matthew Fitzsimons
(4,130 Views)
and id you use simple things... Like the array of boolean and an array of strings. And in this, you could write the names.
What you think?
Software developer
PORTUGAL
(4,127 Views)
You can customize a slide control to look like radio buttons, but it won't resize nicely. I would also say go with the listbox. I use it and it works well.
___________________
Try to take over the world!
(4,124 Views)
The issue of using both is they would have to scroll and aligning the boolean to the string label together.  I belive the list box would work for this application.
Matthew Fitzsimons
(4,121 Views)
Thanks all for the quick suggestions.  The consensus is the list box is the simplest to implement and will work for this application.
Matthew Fitzsimons
(4,109 Views)
