Multiple Excel Sheets of the same Workbook
Hi
if anyone know where is exactly the problem here,in order to inser each row of the table in a different worksheet of the same workbook
by the way the moment i try to use a loop with excel get worksheet,to link the indexation with the worksheet index i get error and it doesn't work1.png
or i have to use this one with some loop with "open new worksheet.vi"
This VI is "write table to XL" from find examples
i really need help to solve this
thanks
(2,744 Views)
i figured a way to do it,i have now a problem in programmation in order to make each row in a different Excel Sheet,if anyone could figure what i have to change1.png
(2,724 Views)
The description of the problem isn't very clear. Would it be possible to elaborate on the desired behavior?
Jeff L
(2,688 Views)
i want to insert each row of a table from labview to excel in a different sheet of the same workbook,1st row in the 1st sheet and so on.to finally get 1 workbook full of sheet,that each one contains just one row
(2,686 Views)
(2,683 Views)
