Multiple FFTs Back-to-back
I am attempting to take a 128-point FFT N times where the output is a 2D array that is 128xN.
I have a current VI that uses the FFT.vi block where I send in 640 samples. This should generate 5 FFT outputs compounding into an array that is 128x5. However, once I connect the FFT size port to an integer control set to 128, I am limited to a 1D array that is 128 entries long.
Is there a simple way to achieve this functionality? Essentially, I just want the FFT to repeatedly run for each new set of 128 samples until the samples run out.
(1,366 Views)
Accepted by topic author fpga_sim_lv_guy
Add a for loop to subset and cycle through each set of 128 samples, compute FFT and get an array of FFT values.
Santhosh
Soliton Technologies
(1,341 Views)
This almost looks like a "poor man's" JTFA. If you have the advanced analysis toolkit (included with LabVIEW professional), there might be better options.
Can you explain from a more general perspective what the data represents and what you are trying to get out of it? Do you have some example data?
(1,315 Views)
