Multiple FTP connections
I'm using Labview 8.2 with Internet toolkit. I'd like to connect to multiple FTP sites, and download files from all sites simultaneously. I would simply use parallel cycles to do that, but it's not possible because the toolkit's FTP VIs are not reentrant, so for example i can't run two "FTP Get File.vi" at the same time. Do you think i could modify those VIs, making them reentrant, or there is some technical limit that allows only one FTP download at a time?
Message 1 of 10
(5,819 Views)
I am not sure, but if you place FTP Get File.vi into an reentrant wrapper VI, you will be able to use it simultaneously.
Message 2 of 10
(5,818 Views)
You can use a non-reentrant wrapper for a reentrant VI, not viceversa...
Message 3 of 10
(5,814 Views)
I made something like this with TCP/IP, not with FTP. I started for every TCP client a new reentrant thread with VI Server and 8-option and could read TCP simultaneously from all clients. I think it should work.
Message 4 of 10
(5,808 Views)
The time expensive job is done by TCP Read Stream.vi (which is reentrant). If you set as reentrant the whole direct call chain from FTP Get File.vi to TCP Read Stream.vi, I believe it should work. It seems that the only vi in the FTP toolkit keeping internal data is FTP Registry.vi, which is not part of that chain.
Paolo
LV 7.1, 2011, 2017, 2019, 2021
Message 5 of 10
(5,791 Views)
Thanks Paolo, i tried to set as reentrant all the call chain to TCP Read Stream.vi; i also tried to set as reentrant all the FTP VIs, except FTP Registry.vi which looks like a functional global. It seems to work, i can download from two FTP sites simultaneously, but the gain in performance is very low. Parallel downloading (two groups of files from two sites) takes only 10% less time than serial downloading (one site at a time). Where's the bottleneck? Maybe total network speed?
Message 6 of 10
(5,757 Views)
I was trying to FTP to multiple devices and I had problems. I came across your posting on ni.com. I tried making the FTP vi from the Internet toolkit reentrant, but it gave TCP/IP error. Do you have any suggestion ?
LJ
Message 7 of 10
(5,665 Views)
We need more details.
What's error code and location?
What's LV version? I used 8.2
Message 8 of 10
(5,652 Views)
I got a TCP/IP open connection error from FTP open session.vi. I am using Labview 8.2.1.
LJ
Message 9 of 10
(5,644 Views)
In my version there was a little bug in FTP open session.vi: the error out of Create semaphore.vi was not connected to the error in of FTP registry.vi. Try to fix it...
Message 10 of 10
(5,639 Views)
