Multiple File Select?
I can't seem to figure out how to present the user with a file dialog that will allow them to select multiple folders out of those present in a current directory. Does anyone know how to/have some code that will do this?
(4,198 Views)
I don't know of a straight forward method.
Check out this info from the Developer Zone: Multiple-file Select Dialog Box
DESCRIPTION:  "This VI calls a Windows API dll which pops up a multiple-file select dialog box. The title input is a string and will appear at the top of the dialog box. The file type list is a two column string table containing file type pairs. Each pair consists of what string will be displayed in the file type drop-down box on the dialog box and a string of the file extension in the form "*.*". The VI returns a list box containing the absolute paths of all files selected as strings, as well as the number of files selected. "
Message Edited by JoeLabView on 06-20-2007 03:35 PM
(4,196 Views)
I also found this thread where they discuss opening multiple files.  HERE
Message Edited by JoeLabView on 06-20-2007 03:39 PM
(4,188 Views)
Ive made a quick example for you. See you this helps.
It's made on labview 8.2
Software developer
www.mcm-electronics.com
PORTUGAL
(4,175 Views)
