Multiple Graphs from 1 input
I have 5 thermocouples wired to read through a serial connection. The output is the 5 temperatures in sequence, one after the other. So as it constantly runs, it gives me the temperature for each site one after another. Is there a way to make this input into 5 different graphs or 5 plots on the same graph using a loop or some kind of structure. I'm using just a slightly modified version of this vi so could someone tell/show me how to get this serial input into either 5 graphs based on their order or at least 5 lines on one graph?
Thanks!
(2,499 Views)
Change ">> Temp readings array >>" to a 2d array. You might have to "Transpose 2D Array" just in front of the graph terminal. And you might have to use "Build array" instead of "Insert into Array".
(2,488 Views)
