Multiple IrDA Dongles?
How can I install several IrDA Dongles on a Windows computer and communicate through them individually with LabVIEW?
(2,747 Views)
As long as you install them as serial ports, you can communicate through them very easily with LabVIEW.
I seem to remember running into difficulties with the IrDA on a laptop previously, though I believe that my difficulties were because I was trying to use the IrDA for NRZ (or was it RZ??) serial protocol, instead of the usual IrDA protocol.
If you have trouble installing multiples, try going with a USB. As long as the USB version can install as normal serial ports, you are okay.
Good luck, and please follow up with your results. I'm sure someone would be interested in your success (or failure) besides you and I.
(2,747 Views)
