Multiple Timed Loops on Same Board
Howdy,
Within a given VI, Is it possible/advisable to mix differing timed loops which act on the same M-series DAQ board? I wish to use one TL to do a single point acquire at the mega-Hz rate while doing I/O on another channel of the same board but at the kilo-Hz rate.
Matthew Pausley
NC State University
Raleigh,NC
(2,961 Views)
I doubt that it is even possible to do singel point at MHz rate. You should do this continious. I believe there is only 1 AI sample clock on most M-boards. But you could use a counter for the kHz channel.
Ton
My LabVIEW Ideas
(2,949 Views)
Also keep in mind that: all AI channels will have to be acquired in same task at common sampling rate.
Yu cannot acquire different AI channels at different rates at the same time. Reason, all AI cahnnels share a common ADC
The same limitation holds good for AO channels too
(2,943 Views)
Thanks to everyone for the advice. Sounds like I have a fundamental problem with my approach/knowledge. Back to the tutorials!
Matthew Pausley
NC State University
Raleigh,NC
(2,930 Views)
