Multiple Trigger Level Data Collection
I'm having some difficulty with a unique data collection problem. I'm using DAQ Assistant to collect and display voltage data on a graph and in numeric indicators. I need to add functionality, so that when the user clicks a control, the incoming data is sampled and shown in a table. Each sample should occur at a succesively higher trigger level-- i.e., 1st sample when channel 0 is near 1 V, 2nd sample at 2 V etc... Is this possible using Labview 8.6? I have experimented with the Trigger and Gate function, but have been unable to trigger the manual trigger at successively higher levels. Any help or ideas would be appreciated!
(2,437 Views)
Hi Sailorguy,
Please have a look at this forum and see if it helps. Thanks!
Ipshita C.
(2,419 Views)
