Multiple VI's
Is it possible to launch several VI's from a parent VI and to still have the
parent running? If so how
Tom
(3,058 Views)
Hi Tom,
for this way I use following:
First I'm creating a notifier which i wire into the placed SubVIs. So I know
when they have to stopp execution by checking it's avaibility. In the MainVI
you can create a loop, which also checks if the notifier is avaible. When
you want's to stopp the execution destroy the notifier somewhere (Main or
SubVI's) and all other will also stopp.
Hope that helps
Henrik
"Elettronica (UK)" schrieb im Newsbeitrag
news:3b77b9e2$0$8508$cc9e4d1f@news.dial.pipex.com...
the
> Tom
(3,058 Views)
Tom,
While the "Parent" VI is running, if you programmatically launch another VI
(that has front panel), the front panel of the subVI will cover up the
parent's... but, if you had other loops on the parent diagram, say that
checked for alarm conditions, etc., they would still be running and doing
their job.... while the user is now interacting with the front panel of the
subVI. A global variable can be used to signal the subVI to exit. When you
exit the subVI, the parent's front panel re-appears.
Hope that helps,
Bill
Elettronica (UK) wrote in message
the
> Tom
(3,058 Views)
Calling a subVI will delay the execution of things that have a dataflow
dependency, but not things in parallel. This means that things that do
not directly depend on the output of the subVI will continue to execute
while the subVI runs.
What happens when the objects are in a loop? A loop diagram cannot
begin another iteration until each node in the diagram completes the
current iteration. If you do not wish for the nodes to wait on another
within a loop, it is best to break them into separate loops that are
less dependent on each other. If you need to add communication back,
you can do so with occurrences, notifiers, queues, or even local and
global v
ariables.
Finally, another way to do this with subVIs is to make the call into a
VI Server Run method. This has an option to not wait.
Greg McKaskle
(3,058 Views)
