Multiple Y Scales on XY Plot
Here's my dilemma...I've got an XY plot with 3 Y scales and a single common X scale.
I'd like to be able to set the individual Y-Scale maximums using a Property Node, but when I go to create one, I see only a single Y Scale/Range/Maximum entry...
Is there a way I can access the 3 indivdual Y Scale maximums through a Property Node?
(2,687 Views)
Hi Steve257,
select first the y-scale which you want to change. The property is "Active YScale". See the attached picture.
Mike
(2,676 Views)
Great! Thanks.
I knew that something had to be in there, but couldn't find it...I guess as I get more experience with LabView (I don't have that much), I'll learn more of these tricks.  Till then, I've got this forum to help me out of a fix.
Again, Thanks!
(2,659 Views)
