Multiple Y-axis and Farnell instrument driver
Hi all,
First Question:
I would like to have 4 plots on the Y-axis (3 on the opposite side) but this will reduce my graph size.How can I get away with this? I am using Laview 6.02.
Second Question
I am looking for a Labview driver for a Farnell AP 60 - 150 Requlated Power Supply unit. Does anyone know where I can find this driver or company who develope the unit?
juni
(2,605 Views)
> using Laview 6.02.
You have multiple options. If you add data for four plots, they will
default to going to the same axis or scale. This is fine if the plots
will be in the same or similar data range. If you popup on the Y scale,
you can duplicate it and swap sides. Do this until you have as many
scales as you like. Then you can popup on the plots in the legend and
choose a particular Y scale for each plot.
Greg McKaskle
(2,605 Views)
