Multiple analog signals in same graph
Kindly suggest me  that how to show 3 analog signals in same graph & it should be continously running.
i have tried but i could not find success however same thing i have implemented by chart.
Kindly suggest me by an example vi.
Thanks & Regards,
Vipin Ahuja
Message 1 of 9
(4,088 Views)
You would want to use waveform chart and not graph. Post your current code for more help.
Message 2 of 9
(4,085 Views)
Why on earth would you say that you can't use a graph?
Turn on context help. Go to the block diagram and move the mouse over the graph indicator. The help window shows the various inputs to a graph - ie a 1D waveform array.
Message 3 of 9
(4,079 Views)
Hit post too soon.
To append new data to old, you can use a shift register or create a limited length buffer to keep the data from growing too large. Similar to the example called XY Chart.
Message 4 of 9
(4,075 Views)
To support with Dennie, here is the vi. Have a look at this, probably this might help you to carry on with your work.
LV 8.0, 8.6, 2011,2012,2013 WinXP
Message 5 of 9
(4,068 Views)
Thanks for your response.
This vi has almost resolved my problem except that i want graph's time axis should move ahead & backward data deleted as new data comes like 10-20 seconds data shown in graph & then if 20-30 sec data comes it should automatically delete 10-20 sec graph data & should show 20-30 seconds graph and similarly it is going on.
Can you suggest how to do it?
Message 6 of 9
(4,060 Views)
This is just example and one of my old VI. It resembles to your project.
Or
try and make a search on forum as "multiple plot" and see where does it end.
Hope this may helps you.
Message 7 of 9
(4,057 Views)
Hi
Check this out probably this is the one u asked i think....
Message 8 of 9
(4,033 Views)
No,  i want graph should move like a chart with every second updation.
Why i choosen graph then because i want a horizontal cusror which is not available in chart.
So i want this type of graph with horizontal cursor.
Message 9 of 9
(4,026 Views)
