Multiple button array alignment
I have these buttons that were created a long time ago for a large project. The button properties tell me they are all the same size but the don't line up anymore. Because of the many local variables attached to them, it would be very difficult to start over with a better method so I just want to fix these and move on. This is just a snip from the original program so there's no code attached.
(2,257 Views)
Hi RHutchings,
you may try to change the properties of the array elements in each of those arrays…
It might be simpler to replace the array element (aka button) by a fresh one. I prefer those from "System controls" palette, because of their "user expected" appearance.
(2,247 Views)
Accepted by topic author RHutchings
By replacing 1 button in each array to a new Silver button and then selecting one from each and setting their height to 24, this is the result.Button array.png
Qestit Systems
Certified-LabVIEW-Developer
(2,234 Views)
Thank you very much. I can always rely on you guys!
(2,218 Views)
