Multiple calls to SubVI using Vision Acquisition
Sorry for the late reply. Below are the version numbers you asked for
NI-IMAQ 4.6.1
NI-IMAQ I/O 2.5
NI-IMAQdx 3.8.1
Message 11 of 15
(1,264 Views)
The Version of IMAQ I am testing with is 3.9.1.  Could you try upgrading to this version and see if it fixes the issue?  You can find the drivers at ni.com/downloads.
Greg H.
Message 12 of 15
(1,257 Views)
I installed the new drivers. Below are the new version number. But still getting the same error.
NI IMAQ 4.7
NI IMAQ I/O 2.6
NI IMAQdx 4.0.
Is there any way you can attach the drivers you are using?
Message 13 of 15
(1,248 Views)
The drivers that I have were downloaded from our website.  I am imaging a 64-bit machine to match your setup and will try to recreate the error.  I post my results once I have given it a try.
Greg H.
Message 14 of 15
(1,237 Views)
I think it may have something to do with the express VI.  Can you try using the attached VI that I modified using the low level IMAQdx calls?
Greg H.
Message 15 of 15
(1,225 Views)
