Multiple channel configuration along with scaling
Hi everyone,
my program is regarding multiple cahnnel configuration using cDaq and NI9203
Please fingdthe program attached.
Problem is I´m unable to run the program without Setting the tast terminal. So connected a Task terminal, but then it didnot work untill selecting a Task. After selecting the Task, as expected it works according to what has been already configured in Task.
Please suggest me how to correct this and be able to configrue each channel
Thanks a lot in advance
Best Regards,
Deepa
Message 1 of 9
(4,085 Views)
Hi Deepa,
use DAQmxCreateTask to create a "fresh and clean" task instead of wiring a task reference…
Hint: each scale name should be unique and  "non-empty" to avoid errors.
Message 2 of 9
(4,076 Views)
Hi GerdW,
Thanks a lot for the Input. will try implenting it
Message 3 of 9
(4,068 Views)
I tried it, But then I am getting error.
Is it possible to provide all the channel as a Options to configure according to the need of user?
I mean if s/he requires only 5 out of eight channels they configure those five with Name of the Task and channel
Best Regards,
Deepa
Message 4 of 9
(4,041 Views)
What error are you getting?  Show us your attempt.
Yes, you do what you are asking for and the way you were told to do it.
Message 5 of 9
(4,036 Views)
Please find the attached vi with Task and error generated
Message 6 of 9
(4,030 Views)
Hi all,
Now with the attached vi. I am able to get the Output without scaling.
When the scaling is involved error Pops up saying  AImin should be Minimum of yintercept.
I did search about this error and sét the AImin from 0 to -20m. Still then I am getting the error.
Any suggestions are greatly appreciated
Message 7 of 9
(4,017 Views)
Your Maximum Value and Minimum Value inputs on the Create DAQmx Channel need to be based on the values AFTER the scale was applied.
Message 8 of 9
(4,014 Views)
I tried AImin -50 and AImax +50, still then it Pops a error stating that that value of AImin should be greater than and lesser than y intercept value
for example: If y intercept is -25... it states that AImin should be lesser than -24.9 and greater than 25.06....
Message 9 of 9
(4,002 Views)
