Multiple channel data with different time stamp logging
I have peaks and valleys from multiple channels with different time stamp but I am not able to log to a single file. Any idea on how to do this?
(3,151 Views)
You don't have different timestamps (you have an integer converted to a double) and you are writing to four different files so your question does not make any sense to me.
(3,145 Views)
Hi Dennis,
Sorry for that I have modified the VI.
Because the peak and valley of every channel will occur at different time and I want to log the peak/valley with the time stamp.
How can I log them on the same file.
(3,139 Views)
Check out this example:
Simultaneously Write and Read TDMS Data To/From The Same File
http://decibel.ni.com/content/docs/DOC-7982
(3,085 Views)
