Multiple channels dynamic data to array, then save to Excel
I acquire data from multiple channels (4-5) and I would like to collect samples at low rates (10 Hz for 3 minutes max). For various reasons I use Dynamic Data type, although I know, that it is not the best way (some say that it is an evil data type 🙂 ). I would also like to save acquired data to a file (the best option would be excel data file).
If I acquire data 10 times per second, it is quite slow to save it to excel (it is the slowest option of all data types). So I would like to fill an array or a matrix with acquired data and then write it to excel file (I use Write to measurement file). But I do not know how to do it - if I convert DDT to DBL, build an array and connect it to shift register, it works but I lose the column names information and I lose time. If I connect to build array one DDT and then from SHIFT register another one, it returns 1D array of DDT. I would like to have 2D DDT, which collects all the information from the loop.  Would there be any suggestion how to solve it?
I am sure that it would be easier to solve my problem with DBL data type but I also use Select Signals VI which is the VI I am not able to substitute at this moment.
Have a nice day
Pinca
(4,154 Views)
Accepted by topic author Pinca
I'm not sure if there's a question here, or what.  To do what you say you want to do, acquire data from 4-5 channels at low rates (10 Hz for 3 minutes) and save the data to an Excel file (I assume you really mean Excel, namely a file with the extension .xls or .xlsx) is really a very easy thing to do in LabVIEW, especially if you do not use:
  • DAQ Assistant
  • Dynamic Data
  • Write to Measurement File.
Indeed, you seem to realize this, but I guess you are going to "do it the hard way", anyway.
Good luck.
Bob Schor
(4,132 Views)
You need to take one or more of the free tutorials and read the LabVIEW help. A build array can create a 2D array if you configure it correctly and you can substitute the Select Signals easily.
(4,117 Views)
