Multiple channels modulation simultaneously NI-RFSG
Hi! Hope you are fine!
I did some research in the example finder in LabView but I coudn't find anything similar.
The thing is that I need to generate multiple channels modulation simultaneously in PXIe-5820 equipment, which is NI-RFSG compatible.
The channels modulation preferred is DVB-S2, but APSK, QAM, will work fine too.
A example of the channels needed is showed in the attached figure.
Anyone have some advice ?
Channelsss.jfif
Thank you in advance!
Message 1 of 1
(1,187 Views)
