Multiple clients reading data from a single server laptop (wireless Network)
                 I need some help on setting up a single wireless server (TCP/IP I think) to allow multiple 15-20 client laptops with wireless network card to real simultaneously  a string of numbers in real time Help ? Any sugested examples I am new to communications in Labview.    The string of data is not long, maybe 40-60 numbers at 1Hz. I am trying to set up the framework for a teacher laptop running a simulation and having the students read the output data display that data and the run some exercises afterwards.  Thanks for your time and help.
(2,477 Views)
There's an example included with LabVEW that should get you started, find it at  "Help -> Find Examples"   then  "Networking->TCP & UDP-> TCP Multiple Connections.lvproj"
MC
(2,437 Views)
Thank You Time to buy a wireless router and start programming.
(2,423 Views)
