Multiple cluster type def not updating
I combined Cluster A and Cluster B with bundle by name into Cluster C.  Cluster C is passed into a state machine through a shift register.   In some states, there are subvis with Cluster C as an input.  All the Clusters are type-def,
When I change Cluster A, I would expect Cluster C to update as well, but it became broken.  Why is that?
Kudos and Accepted as Solution are welcome!
Message 1 of 28
(3,455 Views)
I suspect the C in question is not linked tot he type def. Youcan tell be right-clicking it and if it has a option to Open Type def... it is linked.
Ben
Message 2 of 28
(3,452 Views)
I checked.  All of them are linked.
Message 3 of 28
(3,435 Views)
Did you try placing cluster C on an empty VI and seeing if it updates there when you edit one of the clusters that make it up?
LabVIEW 2012
Message 4 of 28
(3,431 Views)
Then I would switch to the wiring tool, switch on the floating help and then start floating over all of your wires to make sure they are what you expect. When defing the types of SRs LV will demote SR if you slip up.
So see what theire help says about your wire types.
If I think of anything else, I'll update.
Keep us updaed,
ben
Message 5 of 28
(3,424 Views)
Yes, if I place cluster C on an empty Vi, and change changes to it, the update occured.
Message 6 of 28
(3,386 Views)
All the date types are as they should be.
Message 7 of 28
(3,384 Views)
Try test.vi.
If you add something in the test cluster type def, test.vi will become broken.
Message 8 of 28
(3,382 Views)
Sorry but I could not look into this since there where so many missing type defs by the time I disconnected it was meaningless.
Try using a "save for previous..." and choose the same version of LV (this will give you a dialog and let you save the VI and its sub's to a new folder). That way ou will get all of the type defs thta go with your demo.
another approach would be to open the "Test" and look at the hierachry screen with full paths showing and flaot over each sub-vi/ctrl to ensure you did not miss anything.
I tried!
Why do you have tab controls in those cluster?
Ben
Message 9 of 28
(3,368 Views)
Sorry, I thought I included everything.  I made a source distribution.  This should work.
Message 10 of 28
(3,360 Views)
