Multiple curves on XY graph
How to plot multiple curves on XY graph.
Here is a solution for 2 curves, but if the number of curves is important (e.g. 10) this method becomes boring.
One more detail - all Y curves share the same X.
(7,935 Views)
This depends on the incomming data.
1.  If they all share the same Y data then just wire it to the same Y array.
2.  Ideally the X data is in a 2D array and you can do it in an autoindexing loop.
       For each X set
             bundle XY and autoindex out
Plot the answer as a multiXY plot
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(7,933 Views)
My first thought was to have the data be in a 2D array and then you can do all of the work in a FOR loop to create the cluster for each plot and the autoindex out to the XY Graph.
GCentral
(7,916 Views)
Well, to avoid confusing I define more exactly my setup (for simplicity for just 2 curves).
There are 3 arrays of size N: X, Y1, Y2.
Y1 and Y2 share the same X.
If I properly understood point (1), I build an array from Y1 and Y2 (using Build Array)
And this new array (let say YY) "unify" with X array (using Bundle).
Then Bundle output wire to XY graph.
Correct ?
(7,906 Views)
Accepted by topic author Pavel_47
Maybe this will clarify what we are saying.
GCentral
(7,898 Views)
Yes !
It's exactly what I searched for.
(7,884 Views)
Had a hard time following the above until writing out another description for the solution VI:
For non-uniform x-axis data, curves are generally represented as 1-D array X data and Y data pairs.  A method for minimizing calls to shared X data is as follows:
If the X-axis data is shared, build a 2-D array out of the Y-axis 1-D arrays. Then use a For-Loop to index through the 2-D data, bundle it with the X data, and autoindex out the array of clusters to an XY Graph.
(5,811 Views)
