Multiple instances of same vi showing graphs
I need to know if it is possible to set a controled name in front of the name of a vi in the taskbar, so if I got a vi called "display.vi" and it displays data from a possition called 3m, it is named "3m - display.vi", and mayby another "display.vi" with data from 5m the name is then "5m - display.vi"
It is purely Labview8 programming, I got no modules for labview except builder.
I hope you can help me
JFN
(2,459 Views)
Hello jfn,
there's a property node for vi's to change the window name! It corresponds to the wibndow settings of the vi properties when you right-click the vi icon.
(2,455 Views)
