Multiple instances of the same VI?
Hi all,
I had read the disscussion so far happen on this topic. I had tried out using the VIT to run the multiple instance of the same vi. I had put the VIT by dragging teh icon also but still it stops when vit called and run the main program after completion of the vit. I want to run multiple instance of the same vi at a time. Plz let me know if any one has the solution.
Some suggsted to visit SearchVIEW.net and find Kyle Gupton note on that. I also tried it out but not get any such note. Plz guide me how to solve the problem.
Thanks.
Vishal
(2,572 Views)
Hi Vishal,
Please find attached VIs based on the article "Cloning Front Panels -- Refinements to a VI Server Technique
(http://zone.ni.com/devzone/insights.nsf/2d17d611efb58b22862567a9006ffe76/3f078841321aca4686256acc00685b15?OpenDocument)
The VIs are generated in LibVIEW 6.0.2
Regards
Regards
Ray Farmer
(2,572 Views)
