Multiple instances of the same VIs in cRIO 9074
Hello All,
I am deploying my application to cRIO 9074 by clicking on the execution arrow on top level vi. When deploying, LabVIEW deploys multiple instances of the top level VI and multiple instances of some subVIs. In result, the top level VI does not execute, cRIO loses communication, the "Lost communication" popup message periodically appears and disaapears. I think it started doing this today, while no changes in the installation of system SW were done at all. Any ideas why this happens?
Or how do I get rid of this effect?
I run a search on forums and found one case like mine, without any published solution.
Attached is the application deployment report. Any help is very much appreciated.
Pete
(2,306 Views)
Can you post your VIs and project files?
(2,282 Views)
