Multiple notch filters
I am no DSP expert but am trying to realize a filter that will notch 60 Hz and a specified number of harmoinics from a signal.  I have routed my signal through muiltple notch filters (one for each harmonic) with a decreasing Bandstop Attenuation.  This works except the attenuation increases with harmonics and not the other way around.  I dont think my aproach is correct.  How do I cascade IIR filters in labview (8.21)
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(3,428 Views)
What you are looking for is called a comb filter. The name comes from the comb-like appearance of the attenuation curve.
I am not sure how to implement one in LV. Especially with a requirement to be able to specify the number of harmonics. Probably use a combination of an adjustable low pass filter and the comb filter.
None of my filter books list comb filters in their indexes, so I will have to think about it a bit.
I am pretty sure that a synchronous filter filters harmonics, so maybe I can come up with something.
Lynn
(3,425 Views)
There is a comb filter in the digital filter design but it made a comb using all harmonics over the sampleing frequency.  This is not good since I am notching out a few harmonics and the Fs is 500k/sec.  If a can combine this with a low pass filter it might work but I dont want to use the addon toolkit if possible since the client doen not have the toolkit and wants all source code.  Thanks for any advice all will help.
Paul
Paul Falkenstein
(3,418 Views)
