Multiple objects tracking in a labview and vision development module
Hi experts,
i am doing multiple objects tracking of some particles. I follow one research paper to do the image processing. I already developed my own module but need to see the authors model to validate. I try to copy the blog diagram from that paper but giving some error in wire connection how can I solve this issue. Moreover, I need to know that how can I import the Vision assistant 1 images to vision assistant 2, as in the paper the author does the image processing, classification and object tracking in vision assistant 1 and pattern matching in vision assistant 2. How they import the processed image to vision assistant 2.
Thankyou
(1,471 Views)
I recommend you to understand the basics of NI Vision Assistant and how to use that tool for image processing and to convert that into LabVIEW VI, before duplicating the content in the paper to Vision Assistant.
For Vision related Queries Please use Machine Vision - NI Community
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(1,455 Views)
