Multiple pattern lines in path's Browse Option
 I want to have several pattern lines when browsing for a path - see attached example.
Any idea how to do this in LabVIEW?
(3,270 Views)
Hi malosh,
      I don't know if this is possible using functions from the File palette, though, here's a solution that uses the Windows API.
http://sine.ni.com/devzone/cda/epd/p/id/4737
Cheers!
"Inside every large program is a small program struggling to get out." (attributed to Tony Hoare)
(3,265 Views)
