Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Multiple plots in graph-How can I select which plot appears before the others
JE
Member
01-22-2004
01:01 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I am displaying two plots in a graph and one plot tends to cover the othe one. How can I make the hidden plot appear in front of the other one?
0
Kudos
Message
1
of 4
(3,090 Views)
Reply
Re: Multiple plots in graph-How can I select which plot appears before the others
Joe_Guo
Active Participant
01-22-2004
02:07 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
change the build order. If originally data1 is element1 and data2 is element2 when you building the array that was fed to the graph, then wire data1 to element2 and data1 to element1.
joe
1
Kudo
Message
2
of 4
(3,090 Views)
Reply
Joe_Guo
Active Participant
01-22-2004
02:14 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
the above paragraph is illustrated in the attached image.
Joe
Snap1.gif 3 KB
0
Kudos
Message
3
of 4
(3,090 Views)
Reply
JE
Member
Author
01-22-2004
03:50 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Thanks for your help,
Jerome
0
Kudos
Message
4
of 4
(3,090 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
