02-09-2023 01:04 PM - edited 02-09-2023 01:50 PM
Here is my program. All I need is to show on one waveform CV[%], SV[C], PV[C] and I totally don't understand how to do it because LabView isn't my strong side. Please help me ;/
Solved! Go to Solution.
02-09-2023 01:31 PM - edited 02-09-2023 01:36 PM
Hi xFino,
@xFino wrote:
Here is my program.
No, there is just an image of the block diagram…
We cannot edit/run/debug images in LabVIEW!
(And you even forgot to use AutoCleanup before posting, so the code is quite a mess.)
So you even are not capable of opening the context help window, to place a chart on your frontpanel, to look at its terminal in the block diagram to see how to wire it in the context help and then follow the suggestions on how to provide multiple plots to one chart?
Help:
02-09-2023 01:47 PM - edited 02-09-2023 01:48 PM
I dragged and dropped the file at first time but it didn't attach and I didn't check that, sorry. I fixed my mistake.
I know how to open the context help window and I was trying to add multiple plots by myself but as I said I'm new in LabView and this program isn't my strong side so I don't know how exactly do it.
02-09-2023 01:58 PM
Hi xFino,
Done.
02-09-2023 02:30 PM
Thank you very much man! I know that it's very easy thing and I should do it by myself, but I'm learning. Now I will know how to do it, thanks to you of course. Thank you once again and all the best.
