Multiple selection in a tree without using CTRL or Shift key
Thank you very much for your .vi.  It's really a lot simpler than mine 😉
I'll use "the mouse down event".
Any help on this? Will I have to use the coordinates where the click occured? I never used and seen an example with it...
Thanks in advance! Any help would be greatly appreciated.
Message 11 of 16
(1,376 Views)
Yes, you use the coordinates, along with the following VI:  vi.lib\tree\Tree Point Converter.llb\Point to Row-Col.vi.  Not that this VI was converted into a method of the Tree control in LabVIEW 8.0 and later.
Good luck,
-D
Message 12 of 16
(1,373 Views)
Thank you very much Darren!
It works perfectly with the "mouse down event". Smiley Very Happy
Message 13 of 16
(1,364 Views)
What about de-selecting all items programmatically??
I have it set to 0 or 1 item, but no obvious way to deselect an item in the tree.
Thx
Message 14 of 16
(1,338 Views)
For a multi-select tree, you can wire an empty array of strings to a local variable (or Value property) of the tree to clear its selection.  For a single-select tree, an empty string should do it.  I just verified this in LabVIEW 8.2, I'm sure it works in previous versions.
-D
Message 15 of 16
(1,334 Views)
You are correct, although at the time it was not working for me.
What I had done though was to set the tree from a control to an indicator and back.
This fixed the problem. But you are correct, setting it to a null string does de-select a single or 0 select tree.
Message 16 of 16
(1,319 Views)
